SailNet Community - View Single Post - Americas cup triple touch penalty to Kiwi's
post #22 of Old 09-28-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Americas cup triple touch penalty to Kiwi's
Originally Posted by overbored View Post
if you are overtaking and before the overlap you are the burdened boat, as soon as there is an overlap to leeward you are no longer the overtaking boat, you are now the leeward boat and have right a way
The way I read (a) is that the overtaking rules apply to sailboats too.
The way I read (d) is that even if you get an overlap you do not instantly switch to either crossing or leeward you were burdened as an overtaking boat and continue to be thus burdened until their is no longer any risk of collision ie. fully clear.
This is standard ColRegs though. Obviously racing rules are different.
RULE 13
Overtaking
(a) Notwithstanding anything contained in the Rules of Part B, Sections I
and II, any vessel overtaking any other shall keep out of the way of the
vessel being overtaken.
(b) A vessel shall be deemed to be overtaking when coming up with
another vessel from a direction more than 22.5 degrees abaft her beam, that
is, in such a position with reference to the vessel she is overtaking, that at
night she would be able to see only the sternlight of that vessel but neither
of her sidelights.
(c) When a vessel is in any doubt as to whether she if overtaking another,
she shall assume that this is the case and act accordingly.
(d) Any subsequent alteration of the bearing between the two vessels shall not
make the overtaking vessel a crossing vessel within the meaning of these
Rules or relieve her of the duty of keeping clear of the overtaken vessel until
she is finally past and clear.
davidpm is offline
