SailNet Community - View Single Post - Question about singlehanding
Old 02-04-2007
sailingdog sailingdog is offline
A self-tending jib is a jib that will tack itself, and has a single sheet, rather than double sheets, which are traditionally used on jibs.
One common design is to have the jib sheet running to a block on a traveler mounted on the foredeck, just forward of the mast. This design is often seen on boats, like the Sonar, but not as common on larger boats, as it prevents the use of a genoa. However, because the jib is sheeted to a traveller, it can be sheeted in tighter than a traditional setup, and may allow you to point a bit higher than a traditional rig.
Another common setup is to have the jib on a small boom, and have the boom rigged with boom-end sheeting, similar to the mainsail setup on a sailing dinghy.
