SailNet Community - View Single Post - Would you buy an early 80's cored hull boat?
post #18 of Old 09-28-2013
chef2sail
chef2sail's Avatar
Re: Would you buy an early 80's cored hull boat?
Jon with due respect
Look up again what I said I used the word
topside
.....I didnt say topsides.
THe two have very different meanings which ever dumb ass dictionary you want to use.
I said topside as to go topside the topside of the boat, which is usually the deck of some sort
You and you buddy boatpoker are sing the term TOPSIDES. See the s there .the s changes the meaning. Topsides IS the side of the hull above the waterline. BUT I didn't use that word did I now. I used the word TOPSIDE
Now for the other hater, sailingfool, if being right makes me a SN KIA what does being wrong make you....a SN DA.?
Just so you don't think I only use Webster...a good start by the way. Look at the definition in this nautical marine sailing dictionary. It clearly defines topside from topsides. Maybe this will help Boatpoker with his confusion when he gets the difference between using the s and not. His term topside is NOT the side of the boat.
Nautical Dictionary, Glossary and Terms directory: Search Results
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
