SailNet Community - View Single Post - Refrigerator off main breaker?
post #10 of Old 09-30-2013 Thread Starter
GrahamO
GrahamO's Avatar
Thanks Brad,
Do you have a switch that allows you to isolate the refrigerator?
Graham
Originally Posted by Bene505 View Post
We use a dedicated fuse for the fridge, wired directly to the battery. Fuses cause less voltage drop than circuit breakers. Our fridge is always on.
Actually, our compressor is well aft, far from the house bank and right near the shore power charger. I use the (now disconnected) shore power charger's wire. It's 6 gauge. Then I have the fridge fuse coming off that, to a short-ish 14 or 16 gauge wire. 5 amps load. Seafrost says to make sure the compressor gets good power.
Regards,
Brad
Graham and Janaki
Bristol 38.8
GrahamO is offline
