SailNet Community - View Single Post - Attaching Genoa Sheets
post #7 of Old 10-02-2013 Thread Starter
pdqaltair
pdqaltair's Avatar
Re: Attaching Genoa Sheets
No, there will not be chafe. I tested this by barber hauling and the line is actually a few inches away. For the picture I tied it to a rail for demonstration at the dock. But I can see it looks that way.
I also did some more testing and determined that the correct lead is about 2 feet further back. There is enough room for the track, but the forward winch will not be able to turn a full circle. So long as I use the main on the forward winch, I can adjust by cranking back and forth (2-speed winch with little strain). Mostly I play the traveller, once set of up-wind.
I'm going to play with soft shackles. I've used old-school stropes for years but never the new-school sort. Seems easy and secure.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
