SailNet Community - View Single Post - Galley Oven
Thread: Galley Oven
post #3 of Old 10-03-2013 Thread Starter
MSter
Salty
MSter's Avatar
Re: Galley Oven
Good points to ponder, thanks!....
"Where would the gas cylinder be when it the stove is in use?" It appears the regulator attaches in the back of the unit which I believe could be extended.
If it is inside the boat this would be a BAD THING! A seriously BAD THING." Interested to understand how this would be much different from a traditional "plumbed" propane oven. As explained above, the tank could be separated from the open flame via extension by 3-4 feet, thereby removing the cylinder from the "danger zone".
"Also I suspect that you will find that the burners are not stainless steel and rust away within months." Per the ad, the description states the burners are brass and should hold up well in that environment.
MSter
1983 Morgan OI 416
S/V Shamrock
MSter is offline
