SailNet Community - View Single Post - Galley Oven
Thread: Galley Oven
post #8 of Old 10-03-2013 Thread Starter
MSter
Salty
MSter's Avatar
Re: Galley Oven
Originally Posted by nkamper View Post
How much do the gas canisters run for this stove? You could end up spending less up front but way more in the long run if you are using small disposable canisters. Don't know if this is the case, but if they are disposable then that becomes another issue too. I think there's probably a good reason that the marine industry settled on the choices that they did. Just something else to consider.
Agreed. My thought was to refill the 1lb canisters using an available adapter. I was going to install a 20lb cylinder in a vented locker on deck but am trying to avoid plumbing anything below if at all possible. If going this route proves to be unsafe, I will simply do what needs to be done.....
MSter
1983 Morgan OI 416
S/V Shamrock
MSter is offline
