SailNet Community - View Single Post - Pros and cons of steel sailboats
post #1432 of Old 10-03-2013
bobperry
grumpy old man
If we go with the heavier plate and that's all we can get in 5052, then the hull will be closer to 100 lbs. and I estimate another 35 lbs. for the seats and seat frames, side deck, outrigger for the oars, breast hook and fanny hook. I have not estimated the weight of the backbone yet. But I have already used some ideas to reduce seat and seat framing weight and I did not include those weight savings tricks in my weights here. I was trying to be conservative.
Then there is the weight of the oars and rowlocks. Me, 225 lbs., Violet 25 lbs., Ruby 50 lbs.. I am looking right now at designing to a dwl load displ of 500 lb..
I am not figuring on a sailing rig but it could be done. It would probably almost double the cost. I'm talking to Jim Betts about building it and he should have a cost in a few days.
That hull image is a rough cut,i.e. a first try at working within the confines of the geometric process for the origami method. Changes will certainly come. It can only get better.
Bob's Blog ....
bobperry is offline
