SailNet Community - View Single Post - Pros and cons of steel sailboats
post #1435 of Old 10-03-2013
Jeff_H
Moderator
Jeff_H's Avatar
"That hull image is a rough cut,i.e. a first try at working within the confines of the geometric process for the origami method. Changes will certainly come. It can only get better."
"Jeff:
As now drawn I have made allowances for frames at each of the three seats with two frames at the rowing thwart amidships. This leaves the biggest unsupported span at only 36". For nesting the skiff would break right at the forward side of the rowing thwart. It looks like plenty of framing to me."
Your first rough cuts sure look a whole lot better than mine. Humm..I can't imagine why. I'll be interested in seeing the lines drawings as she develops. Rowing craft are always such a balancing act between wetted surface and stability.
My sense is that if you had the framing you mention along with a keelson, breasthooks, and some kind of shelf at the gunnel, that should be all the framing that you need. The nice thing is that if you built her and found her springy you could always add a few transverse floor frames.
Jeff_H is online now
