SailNet Community - View Single Post - Composting Toilets vs. Holding Tank
post #37 of Old 10-03-2013
Minnewaska
Re: Composting Toilets vs. Holding Tank
Originally Posted by MikeOReilly View Post
Hmmm, not sure what you mean Minn. Have you used one? There's nothing very odd or gross about it. The only real difference is men have to sit. And you have to open the trap door. Everything else happens as-per normal.
I have. I've also used an outhouse and porta potty. They're all gross, by common standards. Doesn't stop me, but I know plenty who won't use any of the above. Period.
If you can't fully compost the waste (which takes ~3 months I've read) then it should be dumped out at sea, just like a normal marine head (once you're out past legal limit).....
If you're depositing in it every day, the moment you empty it you have nearly uncomposted waste in the mix. What would you do with it aboard to let it compost for 3 months? Therefore, dumping past the limit is really the only option and I doubt their are many that find themselves in legal dumping areas often enough to be practical. Therefore, the same raw sewage from yesterday's deposit goes straight in the trash I suspect.
Jeanneau 54DS
Minnewaska is offline
