SailNet Community - View Single Post - Lightning protection on 1991 Hunter 30
post #11 of Old 02-05-2007
sailingdog
There is no reason you can't use an unencapsulated metal keel for a ground in a lightning protection system. If the keel is encapsulated, then you will have a problem if you do so...but with an unencapsulated keel, it should be fine.
I'd second reading the website that CruisingDad pointed out... it is very comprehensive and detailed.
Brezzin-
If the compression post was stainless steel, then your grounding system was probably inadequate as a lightning protection system. Stainless steel has a fairly high electrical resistance, which is also why you shouldn't use stainless steel washers in your electrical setup.
sailingdog is offline
