SailNet Community - View Single Post - Interlux Schooner vs. Sikkens Cetol
post #7 of Old 10-05-2013
bljones
bljones's Avatar
Re: Interlux Schooner vs. Sikkens Cetol
SVT, two coats a year is all you need to do to maintain varnish brightwork as well, IF you took the time the first time to lay on 6-8 properly thinned coats on a properly sanded surface.
A varnish schedule is not something you put in your appointment book, it simply means the order of finishing the wood- number of coats, how each coat should be thinned, the sanding order (between which coats), etc., comprises the varnish schedule.
It's 5 o'clock somewhere:
bljones is offline
