SailNet Community - View Single Post - Does a first sail ever go as planned?
post #16 of Old 10-06-2013
davidpm
davidpm's Avatar
Re: Does a first sail ever go as planned?
Originally Posted by capta View Post
Nicely written tale; I enjoyed it, thanks.
A packing gland should leak a little bit, maybe a couple of drips a minute in the slip and a bit more under way. The water lubricates the packing. It needs to be tightened periodically, so check it every now and then.
Servicing Your Stuffing Box - BoatTECH Guides by Don Casey | BoatUS
Should not leak when the engine is stopped.
Just two to three drops a minute when underway.
davidpm is offline
