SailNet Community - View Single Post - Frequency of Changing Oil & Fuel Filters
post #31 of Old 10-07-2013
Don0190
Cruising at a snail pace
Re: Frequency of Changing Oil & Fuel Filters
This is just getting crazy. Regular oil is pretty inexpensive even the "good" stuff. But if you want to use the synthetic and spend more money and then replace it less in order to SPEND THE SAME AMOUNT go ahead. Hey its' your engine!
When it comes to oil only 2 things can go wrong for you: 1 - you didn't have any in the engine, 2 - it went bad because you are stupid cheap
I'm also in the change the oil in the spring camp. I see no reason to allow good oil to sit in the engine all winter collecting water and then use it the next season. I doubt that the oil I put in at the beginning of season went "bad" in 6 months and less than 100 hours of operation.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
