SailNet Community - View Single Post - Pros and cons of steel sailboats
post #1562 of Old 10-08-2013
Classic30
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by bfloyd4445 View Post
you cant take a cutting torch to wood, cut out a piece then weld in another like you can with steel.
Thankfully.. All you need is a Fein, boat nails and another piece of wood.
I can't think of anything in boat-repair much more difficult than patching a hole with plate steel. It looks simple enough to an onlooker, but I've seen even professional welders (cheap ones, I might add) stuff it up totally by not allowing for weld stress and heating.
EDIT: Thinking about this, in theory you might be able to cut wood with a plasma cutter. Dunno.. I'm not silly enough to try it. It's always easier to use the right tools for the job at hand.
Classic30 is offline
