SailNet Community - View Single Post - Interlux Schooner vs. Sikkens Cetol
post #41 of Old 10-09-2013
Minnewaska
Re: Interlux Schooner vs. Sikkens Cetol
Originally Posted by jimgo View Post
Um, you forgot to add the discussion about rebedding - Since I'm going to be redoing the finish on everything, I'm also going to rebed the brightwork. I'm planing on use silicone caulk because everybody says not to buy "marine" versions of stuff since it's just overpriced BS. Although, I've heard good things about something called 5200, and might use that instead.......
Jim, what exactly are you rebedding? I would not think of 5200 as caulk, but as permanent, very permanent, glue. You will likely have to break the item to get it off again.
I've caulked so much stuff over the years, that I'm probably personally responsible for at least one 3M executive bonus payout. However, it doesn't last as long as more modern solutions. Particularly, for hardware that is stressed, like handholds. I'm a convert to butyl tape.
Re-Bedding Deck Hardware Photo Gallery by Compass Marine at pbase.com
Jeanneau 54DS
Minnewaska is offline
