SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #6 of Old 10-16-2013
Maine Sail
Maine Sail's Avatar
Re: Embedded Chain plate maint/replacement
Originally Posted by chucklesR View Post
There is a heavy glass strip at the bottom of the plates, this folds horizontal over where the coring obviously starts (as well as the gel coat).
At the top there is a gel coat cover strip, up under that looks like this.
Those screws are bunged toe rail/cap rail, stanchion bases etc, going through the bases, teak, and folded 'shoebox' lips of the deck/hull.
Chuck,
While you're in there you may want to add some through bolts to the hull/deck joint as opposed to just screw & glue....
______
-Maine Sail / CS-36T
Maine Sail is offline
