SailNet Community - View Single Post - What wood is this cabin sole made off??
post #11 of Old 10-16-2013
RichH
RichH's Avatar
Re: What wood is this cabin sole made off??
I had similar uh-ohs on a quality built taiwanese boat. The strakes were 1/4 thk teak and 1/4 x 1/4 white meranti (?). I found my meranti at a 'quality' hardwoods dealer and carefully 'routed out' all the old and simply very carefully 'inlaid' the new.
For a wet section of sole that began to rot away from underneath in the supporting ply, I cut out a square section of the sole with a very fine 'cabinet saw blade' (on a fein tool), removed the 1/4 thick teak straking and (probably) white meranti without loosening the strake to strake glue lines by careful chiseling/grinding/sanding away the adhering underdecking and then simply re-glued to the rebuilt 'underdeck'. The only way one can determine that this was a repair was to closely look for those very thin 'cut lines' that were filled with 'saw dust filled resin'.
hope this helps.
RichH is online now
The Following User Says Thank You to RichH For This Useful Post:
Cruxandreams (10-25-2013)
