SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #22 of Old 10-16-2013
davidpm
davidpm's Avatar
Re: Embedded Chain plate maint/replacement
So if you look a a boat and see the chainplates topside and there is no way to see any attachment below is their any other way they could have been built that doesn't use a knee or bulkhead or exterior bolts through the hull and is NOT glassed in?
IOW is their any construction method where the chainplates are flush or nearly flush with the hull interior and still allows inspection.
davidpm is offline
