SailNet Community - View Single Post - Best used cheap blue water boats 30-45ft
post #19 of Old 10-19-2013
killarney_sailor
Bristol 45.5 - AiniA
Re: Best used cheap blue water boats 30-45ft
I think you should consider displacement and sail (and anchor) handling systems when considering boats to singlehand. For example, a Westsail 32 is almost 20,000 lbs while a CS36T, just for example, is closer to 15,000. The CS, and lots of similar boats, has a lot more space and is much faster. It is also a lot easier to handle under power getting into and out of docks. It is also a pretty rugged boat. BTW, not saying you should buy a CS, just that there are other directions to look.
As for systems, when it comes to things like winches and wind lasses, many boats have marginal ones since it was a good way for the builders to save money.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
