SailNet Community - View Single Post - How high can you point?
post #9 of Old 10-21-2013
Re: How high can you point?
Originally Posted by Lidgard29 View Post
I'm trying to determine if my 1986 Lidgard 29' sloop points well. Most days we tack up around 100-120 degrees from side to side. In other words, we are 50-60 degrees off the wind. How are other boats doing?
The real question here has not to do with how close to the wind a boat can get but what is the wind angle where a boat makes against the wind a better VMG. That angle varies with the wind intensity (it becomes smaller with stronger winds)
For reefing the sails, or for solving some problem I can bring my boat to an incredible wind angle, even on auto pilot, without losing boat control but the speed will fall to half of what I can get with more 7 of 8 degrees.
Modern performance boats, specially the ones that are designed to be specially good upwind can give you an idea about the best you can have today on a cruising boat and serve as comparison.
A First 35 best upwind angle with 6K wind will be 43.7 and the boat will be made a VMG (not boat speed) of 3.35K. With 16K the best upwind angle would be 39.4 and the VMG would be 5.15K.
http://www.yca.org.ar/Gallery/3108.pdf
