SailNet Community - View Single Post - Ana Capri or Anacapri?
post #35 of Old 10-21-2013
74anacapri
Re: Ana Capri or Anacapri?
Some more images.
The companionway is original, Usually sail with the upper hatch off, the louvers are nice when it is warm, the doors stay out of the way, but don't stop cold. Needs teak oil. Those are new cam cleats for the jib sheets, I had to adjust the angle on them several times so they would release under load, but not too easily. The jib fairlead blocks are original, and could use replacing.
The interior used to have a folding table, I took it out and don't put in the bunk cushions unless needed. Overhead painted with white enamel.
Forward I added the deep drawer under the v berth to keep spare parts. The sink is nonoperational and used to store refreshing beverages. I put a seacock on the sink drain.
I added the big bumpers to the forward hatch to improve ventilation with the hatch closed. Also saves wear and tear when someone drops it closed.
74anacapri is offline
The Following User Says Thank You to 74anacapri For This Useful Post:
BillOcala (10-22-2013)
