SailNet Community - View Single Post - Would you rather own a sailboat or a RV?
post #110 of Old 10-21-2013
TJC45
Re: Would you rather own a sailboat or a RV?
I'm not so critical of Airstream. Fact is most RVs, from small towables to 40 ft plus diesel pushers are made out of a combination of cardboard, plastic, and rubber these days. You can buy quality, but it costs! Personally, i wouldn't buy anything with a rubber roof or anything where the owner is required to maintain the walls, windows, roof, or door openings with any type of sealant. Once water gets in the walls will start to delaminate. That's when things get expensive. On towables i would make sure the axles, wheel hubs etc are up to the weight being carried. Once I'm thru with the struture, next up is usability. Everything from the layout to how the utilities are layed out. to where are the breakers. Just like with boats, you hang around RVs long enough you see some pretty stupid stuff. The idea is to catch it before you write the check.
TJC45 is offline
