SailNet Community - View Single Post - Optimal halyard length?
post #3 of Old 10-22-2013
RedHorizon
Re: Optimal halyard length?
The big question here is what kind of sheave do you have at the top of the mast. If it's wide enough to handle something wider than wire then you have lots of options. It it's sized to fit just wire, then you may need to stick with wire unless you can change the sheave out.
1983 Lippincott 30 s/v Red Horizon
Regent Point Marina Topping, VA
RedHorizon is offline
