SailNet Community - View Single Post - Hello all, I'm a new user but an old sailor
post #7 of Old 10-22-2013
Jeff_H
Moderator
Jeff_H's Avatar
Re: Hello all, I'm a new user but an old sailor
Paulo,
I was not able to quickly find the Cynthia Woods discussions, but from memory (and Kiko can certainly correct me if I have this wrong) the published investigation concluded that the Cynthia Woods, while somewhat close to the then current design recommendations, was none the less constructed within the puiblished standards which would apply.
The report concluded that the damage to the keel from the earlier grounding was:
- more extensive than understood by the people performing the repairs,
-that there should have been more comprehensive professional assistance in evaluating and repairing the damage,
-that the damage was probably made worse by the boat being in a slip which was too shallow resulting in multiple daily groundings with the tide, and
-that the actual mode of failure was a separating of the hull laminate in the keel area of the boat, which initiated with delaminating of the skin below the transverse frames and spread out into the hull.
There are important lessons in the Cynthia Woods tragedy regarding how high impact grounds should be evaluated and repaired that make Kiko's company's findings very helpful reading for anyone who owns a boat or who is charged with evaluating and repairing grounding damage.
My take away was that the visible damage was only the tip of the problem. My sense is that while ultimate failure mode would have been hard to detect without taking off the keel, and may have been nearly impossible to detect with an encapsulated keel, safety demands that a full and proper investigation take place after any hard grounding.
Jeff_H is online now
The Following User Says Thank You to Jeff_H For This Useful Post:
PCP (10-22-2013)
