SailNet Community - View Single Post - Composting Toilets vs. Holding Tank
post #56 of Old 10-23-2013
copacabana
Re: Composting Toilets vs. Holding Tank
Good points above^^^^, plus the installation of a composting toilet is very much within the abilities of any unskilled boat owner, while a wet toilet, holding tank and all the fittings etc. is a much bigger and more difficult task. If you have to call someone in to install it, it will most certainly end up more expensive than a composting toilet.
The C-head is cheaper, as someone has pointed out, but I think you should compare it very carefully to the Nature's Head before buying one. They are both good products, but not really an apples to apples comparison.
Vindö 50
copacabana is offline
