post #4783 of Old 10-23-2013 Thread Starter
Test sails
Originally Posted by JAndersB View Post
One reflection I have with all these test is that, as I have said before, it is very difficult to evaluate the numbers that are given. For instance the Solaris 37 tested in Sweden with Salona 38 and Elan 400 had 2,4m keel, carbon mast, very expensive sails and no inventory nor any equipment. The Elan was a "special edition" for the norwegian importers personal use for competitions, it did not even have an anchor windlass nor any sign of wood anywhere on deck.
How many normal customers will buy boats like these - very, very few. And after that they will load them down. One boat can perhaps take this without a big loss in speed while others suffer more.
And furthermore, it is vey difficult to calibrate instruments, it can take a whole season for me and then I need to recalibrate due to growth on paddle wheel...
Luffe 36,6 doing 9 knots with normal sails in 17 knots thrue? Hm, perhaps but I guess once again in best equipment state and no load. And we will not sail like that normally.
And then we try to get access to test sail ourselves and still meet boats like those above and no wind (very often) or too much wind (seldeom).
So end result is that we tend to buy, testsail and sell. Or?
Anders
Test sails are not all the same. A good test sail is hard to get and few magazines have reliable ones. Voile and voiliers is one exception, Yacht.de is another. Both say how the boat was equipped, the test sail conditions and give exact figures with all elements regarding speed and how it was achieved including sea conditions.
I prefer comparative tests with both boats on the water and even if those two magazines do them they are not the more frequent. The Oceanis 38 was tested in the water with the Varianta 37 with light winds, being the Varianta noticeably fast and I am sure that the Varianta had mo racing sails but cheap ones (you can see on the pictures).
I sail tested once a Luffe 4004. That was a windy day (about 20K) and the boat had non reefing racing sails. Oluf was sailing the boat and with the main alone we were soon doing +8k. Those narrow boats have little drag and can easily get to hull speed, even a bit over it. remember that they were sailing the 36.6 with a spinnaker when they reach 9K with 17K wind. A more light beamy boat like the Pogo 10.50 would probably reach the 9K with considerably less wind or with that wind that speed without a spinnaker. But if you loaded it too much the lose in speed would probably be more noticeable than on the Luffe.
The Oceanis looks like a Pogo...except in the weight, RM and sail area. off course, downwind speed too.
I agree with you regarding the boats being unloaded and with very little tankage aboard. A real cruising boat (except Eric's one) will have most of the time a thousand kg more and not all boats are affected the same way by an heavy load.
Regarding Calibrated instruments that can have some effect but testers are not dumb and for sure they have a look at both instruments: GPS speed and log speed and that limit margin error.
