SailNet Community - View Single Post - We Killed the Pacific Ocean
post #32 of Old 10-24-2013 Thread Starter
casey1999
casey1999's Avatar
Re: We Killed the Pacific Ocean
One thing I do not understand (well I do really understand- its all about making more profit), is why a pepermint patty candy (or many other cadies)has to have a mylar wraper? Or why all the excessive plastic packaging that exist now? Some of this packaging is so strong that you need tools to open the item (like the clear heat sealed clam shell type packaging), and you can end up getting a nasty cut from the sharp edges of the cut packaging.
A lot of this packaging does not get recycled or disposed of properly. It eventually goes to a waterway where it has a life span of hundreds of years.
We really need a world wide regulation on plastics. Either ban plastic packaging or use somthing that will bio-degrade in a short time. Same for other plastics- they need to be biodegradeable.
Back in the hippie era of 60's and 70's we did not have all this plastic, and we all lived a good life, and the oceans and beaches were a lot cleaner. Now plastic is used for everything and discarded everywhere.
Here in Hawaii when the grow pineapple, HDPE plastic tube is layed in the ground to water and fertilize the pineapple. After harvest the plastic tube is cut up by the plough. It eventually winds up in the ocean- just crazy.
We cannot continue to litter the earth with plastic.
casey1999 is offline
The Following User Says Thank You to casey1999 For This Useful Post:
Minnesail (10-24-2013)
