SailNet Community - View Single Post - Yanmar 2GMF, throttle return spring too strong
post #1 of Old 10-24-2013 Thread Starter
rauschpfeife
I recently acquired a Pearson 303, vintage 1983, and I'm still getting to know it. Yanmar 2GMF inboard.
A curious problem: the throttle appears to have a return spring, or something similar, which tends to push the throttle back down to the idle position. There is a sort of clamp on the throttle cable housing, which creates enough friction in the cable to oppose this force. But if I clamp the cable hard enough to keep the throttle in the fully-open position, it's so clamped-down I can't move the throttle at all.
There doesn't seem to be any obvious way to adjust the tension on the return spring, or whatever it is, which seems to be *inside* the engine. Is that possible?
Anybody ever encountered this problem? Suggestions?
PS -- Been looking at the service manual, and I'm starting to get a sinking feeling that all this magic happens inside the injector pump... Somebody tell me I'm wrong!
rauschpfeife is offline
