SailNet Community - View Single Post - Pros and cons of steel sailboats
post #1855 of Old 10-24-2013
smackdaddy
The Elephant
smackdaddy's Avatar
Your comments were that shape has no effect on stiffness, which is the equivalent of stating that a square propane tank is the same strength as a round one. You pressed a spline in the middle, then claimed that a longitudinal would also bulge out near the ends while welded, and thus contained inside a steel hull, the same way your spline out in the open did. Wynand definitely declared himself a racist and proud of it. He also joined the attack on framlessness ,and only later admitted he had built a framless 38 ft Dix design, posted on the origami boats site. You also supported the notion that the steel under my mast support pipes, 13 inches of 3/16th plate, would break before the 3 -5/16th windward shrouds would, and that could happen in the first 4 hours ,. something which hasn't happened in over 40 years.
I stand by all my comments on that site.
Actual quotes or it didn't happen (like most of the other things you claim people said).
If I can use your actual quotes in my BS Yachts Marketing Program post, you should be able to figure it out.
smackdaddy is online now
