SailNet Community - View Single Post - Sailing, safety, & size
post #2 of Old 10-25-2013
Jeff_H
Moderator
Jeff_H's Avatar
Re: Sailing, safety, & size
Having also begun sailing when a 35 footer was a big cruising boat, at most levels, I understand the thrust of your point. But for better or worse, the concensus coming out of most studies on the factors that lead to a more seaworthy boats conclude that the one factor that consistently improve seaworthiness (all other factors being roughly equal) is greater length.
But I also understand that a badly designed longer boat won't be safer than a well designed smaller boat. I also understand that a larger boat can kill people when a smaller boat might simply bruise them. And I also understand that a longer boat in the hands of an inexperienced crew is likely be far less safe for that same crew on a smaller boat.
These things are never so simple that a simple rule can universally apply.
But the really good news is that you prefer the boat you own to all of the boats you have sailed before. To me the most joyful thing in life is being pleased with what you have.
Jeff_H is offline
