SailNet Community - View Single Post - welding and welder options
post #7 of Old 10-26-2013
tommays
tommays's Avatar
Re: welding and welder options
On SS and aluminum you can TIG or you can TIG as any other process is just going to make a mess
While you can MIG aluminum it is done with a spool gun as the wire is to soft to be pushed through a normal gun and that would be yet another thing to carry
For the steel hull boat oxy acetylene to cut and stick to weld
While you can oxy acetylene weld it is about the worst choice and best suited for brazing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
