SailNet Community - View Single Post - Newbie questions after first time taking out sailboat
post #10 of Old 10-27-2013
Delta-T
Delta-T's Avatar
Re: Newbie questions after first time taking out sailboat
More than likely the sails are tired. But I am sure they will not stop you from having fun and learning. Keep in mind you never run a flat sail...EVER! The sail needs curve, just like the wing of a plain, a sail is a plane wing on it's side. But works the same way with lift and pressure created by the shape of the sail, the curve. There are many good sail trimming instructional video's on U-tube about it. Use "sail trimming" for search.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
