SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #286 of Old 10-28-2013
TakeFive
TakeFive's Avatar
Re: Bedding Deck Hardware With Butyl Tape
I have a transom-hung rudder, with two gudgeons mounted on the transom. When I replaced them last year I bedded them with MaineSail's butyl tape, since they are both above the waterline. I cranked down on the screws as much as I could, but toward the end of the season they loosened up. These things have big bronze backing plates and lock nuts, so I know the screws did not loosen. The butyl apparently oozed out enough for the bedding to become a little thinner.
Is butyl the right application for this, or should I look for a curing sealant to bed the gudgeons? If the latter, what would you recommend?
FWIW, I am replacing the Phillips head bolts with hex head, so in the future I should be able tighten them up mid-season without having to remove the rudder.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
