SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #88 of Old 10-28-2013
44Kebeck
Re: Embedded Chain plate maint/replacement
This thread has been of great interest to me as I own a 1988 Irwin 38 MkII. I have the same crazing in the gel coat around the chain plates. I have attributed this to trapped water and the freeze/thaw cycle. I drilled into the glass at the bottom of one plate and water drained out.
After seeing the condition of the removed plate replacing chain plates has moved a bit down my priority list but when I do start the project it will be external plates bolted through the old ones. My only question is the number and diameter of bolts I should use? The plates are 3/8" x 2" x 24".
44Q
44Kebeck is offline
