SailNet Community - View Single Post - welding and welder options
post #24 of Old 10-29-2013 Thread Starter
xymotic
Re: welding and welder options
Originally Posted by Daydreamer22 View Post
Check out the Ready Welder. I use one on my service truck. It's a 24v DC Mig spool gun. Power is from two deep cycle batteries, or three for more heat. Uses shielded wire or plain wire with a co2 bottle. Can do SS or AL with proper wire and gas mix. Gun and cables fit into a briefcase. Welding time varies with battery condition. Took a couple days to weld up a frame for the dump bed on a pickup truck, discharging and recharging batteries. Fixing brackets and other small projects can be done right away.
I took a welding class at our local Community College.
Best wishes however you go.
I've been looking at them for a while. I'm thinking it would be a lot more useful just as a spool gun powered by a regular welder. I've welded with batteries before... Just not to thrilled with the whole concept I guess. I think it'd be cool if I just wanted to repair stuff on the boat. But I actually need to fabricate some stuff at home first.
When you say you use it on your service truck, are you giving it commercial everyday kind of use?
xymotic is offline
