SailNet Community - View Single Post - How much deck over the cabin do I remove?
post #36 of Old 10-29-2013
boatpoker
Dirt Free
boatpoker's Avatar
Re: How much deck over the cabin do I remove?
I am very familiar with Grampians and if the cabin trunk is wet around the grab rails mounts ( as per your photo of sitting water), I guarantee the entire trunk top is saturated with extensive balsa degradation (compost). Re-coring by a pro with the proper tools and experience would be at least 100hrs. labour for the inexperienced probably four times that much.
As to repairing from above or below ... have you ever tried to wall paper a ceiling ?
Resin soaked glass fiber is much heavier and not as stiff as wet paper.
You will never recoup the expense of a repair like this. As long as the bulkhead supporting the mast step and the shroud chain plate knees are sound, consider it a disposable boat, go sail it and don't waste time or money on repairs
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
