SailNet Community - View Single Post - Yanmar 2GMF, throttle return spring too strong
post #10 of Old 10-30-2013
redline
redline's Avatar
Re: Yanmar 2GMF, throttle return spring too strong
If adding a clamp on the cable as pictured above (or the Teleflex version), it's best to put it as close as possible to the control lever end of the cable. If the cable length is significant and/or has several bends, it will add "sponginess" if the clamp is at the engine end.
Also, it shouldn't be too tight - ideally the return spring should throttle the engine back to idle if the control cable somehow let go.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
