SailNet Community - View Single Post - Your Pick for Best Crimpers
post #13 of Old 11-01-2013
Maine Sail
Maine Sail's Avatar
Re: Your Pick for Best Crimpers
Originally Posted by wind_magic View Post
Title says it all, what is your pick for best crimping tool for red, blue, and yellow rings, spades, etc ?
Seeing as you said "best" here's my picks... I will assume red, blue & yellow insulated but not heat shrink?
For me it is AMP PIDG terminals and an AMP 59250 for red and blue terminals and then an AMP 59239-4 for the yellow terminals.
There are other similar crimp tools to these but these are the tools used in the aerospace industry and certified for that use when used with the AMP PIDG terminals. When properly used with AMP PIDG terminals the crimps made are simply beautiful, robust and do not over or under crimp the wire. They certainly can be used with off brand terminals but do be sure they are a copy of an AMP PIDG three piece terminal.
What ever crimp tool you get:
*Pick your terminals and stick to that brand
*Test each size wire in each size terminal to be sure it is making a suitable crimp
There is a LOT of variability in red, blue, yellow crimp tools....
______
-Maine Sail / CS-36T
Maine Sail is offline
