SailNet Community - View Single Post - Uneven Water Loss in Batteries
post #9 of Old 11-01-2013 Thread Starter
night0wl
night0wl's Avatar
Re: Uneven Water Loss in Batteries
Originally Posted by Delta-T View Post
Would it not be prudent to do a hydrometer test on each cell to see if you have a bad cell going? You say you top off batts each month? Was led ever exposed to the air? The only time I have had to add water is when batts are going bad, excessive charging, charger never stops charging because batts never reach full charge. I have not had to add water once this year, two year old batts, but I did not use much batts this year, no long trips.
Am I all wet with the hydrometer test? viscosity testing of a battery?
i'll do a hydrometer check, but being 4 months old, I suspect they're good. In Florida, you have to top off fluid more often. The summer temps are really harsh on batteries.
S/V Jendai
Beneteau 343
night0wl is offline
