SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #113 of Old 11-01-2013 Thread Starter
chucklesR
chucklesR's Avatar
Re: Embedded Chain plate maint/replacement
Based on what you've found... are you going to tackle the other side 'just in case'.. or to match what you're about to create now?
Yes, I'm doing both sides, aft lower and uppers as well as the back stay. The fwd lower will be just a weep hole and inspection port (of some type).
The fore stay is well mounted fully exposed on the end of the bow spit - no need to do it as I can inspect it and tell it's fine.
chucklesR is offline
