SailNet Community - View Single Post - Survey?????? I've never had one
post #14 of Old 11-01-2013
Stumble
Re: Survey?????? I've never had one
Who is doing the survey, how far does he have to drive, when does it need to be done by, what are his liabilities under state law, how detailed is he. Many of these have no bearing on how long a survey may take, or the cost to him of doing it. For instance, a visual inspection of the rigging on any sloop is probably going to take about the same length of time. However dye testing each fitting on a rig is more dependent on the size of the rig.
Frankly I can't figure out why people think a smaller boat is going to be much less time intensive to survey, assuming the same detail of survey as a larger boat. There is still one engine, one set of rigging, one rudder, one set of rudder bearings, one head, one set of batteries, one hull (ok moisture readings take a few seconds, but it doesn't change that much in overall time). Add to this that small boats often have much more cramped quarters, worse access to things.
While I completely get why small boat owners don't get surveys (I don't either) that doesn't mean that the surveyor is going to spend significantly less time surveying a 22' boat versus a 30' versus a 40'. Now as the boats get bigger they may have more systems and greater complexity which could add to the time it takes to do a good job, but that isn't dependent entirely on length.
Greg
Stumble is offline
