SailNet Community - View Single Post - Sailing, safety, & size
post #105 of Old 11-01-2013
JonEisberg
Re: Sailing, safety, & size
Originally Posted by barefootnavigator View Post
Bigger does not mean higher hull speed unless you are talking about motoring all the way.
Sorry, but that is simply wrong...
In general, greater LWL translates to greater speed, whether under power or sail, in ideal conditions, or those less than ideal... In lighter airs, even a modest increase in speed through the water due to LWL can increase the apparent wind, which in turn results in an exponential increase in speed as a result in sailing in a 'stronger' breeze...
Speed does not EVER equate to safety, safety does.
Wrong again...
Speed MAY afford greater safety, on occasion... Faster passage times equal less exposure to weather, speed can often make the difference between reaching a destination before darkness falls, or approaching weather overtakes you... To deny that speed can SOMETIMES be a tremendous advantage in terms of safety, is just silly..
JonEisberg is offline
