SailNet Community - View Single Post - Solo Mast Stepping System
post #8 of Old 11-01-2013 Thread Starter
Kielanders
Kielanders's Avatar
Re: Solo Mast Stepping System
Originally Posted by Sublime View Post
My hunter 260 has a 35' mast that I can raise and lower myself.
The mast has struts on either side which run to the deck to keep it from twisting or swinging.
It uses a gin pole which attaches into a hole on the mast. The jib halyard attaches to one side, the mainsheet attaches to the other and is run down to an attachment point in the anchor locker. You use the mainsheet to raise or lower the mast. Some people have modified things to use an electric winch.
Some diagrams:
The mast struts
The system with gin pole
Looking at your engineering drawings; this is a Hunter designed system? Was the entire system sold by Hunter? Do the struts need to dynamically lengthen as they travel the raising arc? How heavy is your mast? Perhaps my 140 lbs isn't heavy for a 33' mast, but it was beefier than I expected when first lifting. Do you have any photos available of your install?
Thanks.
Kielanders is offline
