SailNet Community - View Single Post - Solo Mast Stepping System
post #9 of Old 11-01-2013
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Solo Mast Stepping System
You'll be amazed the first time you do it. According to a quick search, the tall rig mast on a Catalina 25 is 150 lbs. I didn't have the tall rig, so maybe lop off 15-20 lbs. When I used the A-frame, I had 3 wraps around the winch, and even when the mast was most of the way down (i.e., when I should have had most of the weight on the line) I had total control over it.
A few threads:
Association Forum - lowering the mast
http://www.catalina-capri-25s.org/fo...hTerms=a,frame
In hindsight, I probably could have use dyneema to attach the a frame to the chainplate.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
Kielanders (11-02-2013)
