SailNet Community - View Single Post - Uneven Water Loss in Batteries
post #22 of Old 11-02-2013
mitiempo
mitiempo's Avatar
Re: Uneven Water Loss in Batteries
Originally Posted by Delta-T View Post
And one more for the books...
A damaged battery cable will carry less electrical energy than a battery cable in good repair. A battery cable can become damaged by mechanical stresses or corrosion. It is important, therefore, to periodically replace battery cables that are installed in an environment where there is vibration, movement, or corrosive chemicals. An ohmmeter or a digital multimeter may be used to test a suspected bad battery cable. If the ohmmeter measures a high degree of resistance in the cable, the cable should be replaced.
Sorry no scientific data to back that up.
Agreed a damaged cable can have issues. However a properly made cable with heatshrink using good tinned marine wire and installed properly should not have issues with vibration or corrosion for many, many years.
Brian
mitiempo is offline
