SailNet Community - View Single Post - "Free boat" seaworthiness
post #195 of Old 11-02-2013
NCC320
Re: "Free boat" seaworthiness
Jack,
Re: Using the lift to inspect the bottom. A good many (most) sailboats are rounded on the bottom, and motor boats are generally straight. The lift, assuming it is set up for a motor boat, probably has straight bunks. If the sailboat has a significant curve in the hull, the straight bunks might over stress a curved hull. My C22 had a fair amount of curve and trailer bunks were "bent" accordingly. I've seen other small sailboats where the bottom was more straight and straight bunks wouldn't be a problem. Not sure what the boat you are looking at has. If you have access to any literature on this boat, you might look to make sure that the hull is relatively flat.
Fixed keel may or may not cause a problem in getting into the lift. That one is easy, either it will or it won't go into the lift.
NCC320 is offline
