SailNet Community - View Single Post - Huge Voltage Drain Problem - Ideas?
post #2 of Old 11-03-2013
Gladrags1
Sailor
Gladrags1's Avatar
Re: Huge Voltage Drain Problem - Ideas?
Can you test the voltage of the batteries with a tester when the Xantrex tells you they are at 17%? The voltage would be expected to be very low if that is the case. I suspect you are going to find that the batteries are fine and there is a problem with the Xantrex. Check documentation for Xantrex to see if there are any error codes. Maybe reset it and see if that corrects it?
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
