SailNet Community - View Single Post - Huge Voltage Drain Problem - Ideas?
post #22 of Old 11-05-2013
mitiempo
mitiempo's Avatar
Re: Huge Voltage Drain Problem - Ideas?
Originally Posted by btrayfors View Post
If you're going to play an electrical Sherlock Holmes then you need a proper magnifying glass.
You should have -- ALL boats should have -- an AC/DC clamp-on ammeter. Decent ones are cheap these days (around $60), and they'll save you hundreds of dollars of grief.
Wondering if you have a current leak? Just use the clamp-on ammeter to prove that you do (or don't), and to accurately measure the magnitude of the leak.
Did you really have a 40A current draw with all breakers off, or was the Xantrex lying to you?
No more will you have to say, "I think I have.....". With proper use of a clamp-on ammeter, you'll KNOW you have, or don't have....
You can also know very accurately:
- how much amperage you alternator is actually putting out
- how much amperage your battery charger is actually putting out
- how much amperage your solar panels are putting into the MPPT controller
- how much amperage your MPPT controller is putting into the batteries
- how much amperage your bilge pump draws
- how much amperage just about anything on your boat draws
- how much amperage is being drawn from your batteries
etc., etc.
You get the picture.
Sorry for the mini-rant. It just drives me crazy to watch the antics of folks trying to troubleshoot relatively simple electrical problems on their boats without having even the rudimentary tools required.
Bill
Bill beat me to this opinion and I agree. The list above could be completed to remove any doubt in under 30 minutes probably.
Brian
mitiempo is offline
