SailNet Community - View Single Post - Sailing, safety, & size
post #195 of Old 11-05-2013
outbound
outbound's Avatar
Re: Sailing, safety, & size
As said in prior posts windlass failure is very rare. In a catastrophe ( no juice) you do what you gotta do. I have all chain on my primary anchor . Although I guess I could use the spin halyard but the idea of having chain flying around seems scary. Rather have chain on deck so would use my snuffer lines. Find simple knot easier to work with then hooks. Motoring up to the anchor just have to lift the chain ( can do by hand) and can power over the anchor to break it free. Use primaries not mast winches as they are powered. Would use mast winches in absence of juice but might need the additional mechanical advantage of the bigger primaries. Probably wouldn't need the snuffer trick but for a little bit. Have 75lbs Rocna so anchor and chain will be a heavy lift. A little glass work gotta be better than losing the boat. It's rope not chain going to the winches with the portion of chain on deck under tension or fed into chain locker. Have snatch blocks on toes rails already for the spinnaker so can rig the snuffer line(s) through them quickly. Can't image structural damage from doing this that would threaten the boat.
s/v Hippocampus
Outbound 46
outbound is offline
